minotto
sliding glass door not showing up in plan view
Here is a plan view of a window at the top right (elevation 2' and a sliding glass door at the bottom left (elevation 0).  I've set the parameters to be identical as far as jamb, sash etc.... Is there a way to have the door show up like the window?  I can't seem to find the right parameter.
1490891886_ScreenShot2019-04-06at17_34_40.thumb.png.0af94b51fe61116c218f6422cc60817f.png
Edited by minotto
I see similar from my Revit import Doors,
where Doors use just a Symbol for all Geometry,
where these Symbols have no 2D part.
So I see a single line at best - when selected.
Yes, I could let create VW the new top and side views depending on scale.
I just don’t really need it. But it is a bit distracting when you see just a gap
in your Walls in Top Plan View..
But I think Minottos problem is more just a visibility issue with Classes,
as yo said.
@minottoHi, This issue can arise if something is way off internal origin of the program. Turn on all classes and do a select all and zoom extents.
Display your internal origin. If you have things way off in the distance delete them if you know what they are untill you get Z extents with just your drawing. See if this helps.
It turned out to be a visibility issue with the Sills Class.
Thanks for everyone's input.
