Matster Posted April 5, 2019 Share Posted April 5, 2019 I'd like to be able to attached may screen to one truss and projector to another, then have the weights of each calculate for each, is that possible? or will i have to create an object for a random weight, just to make an allowance? Quote Link to comment
Guest Yordan Kostadinov Posted April 8, 2019 Share Posted April 8, 2019 In Vectorworks 2019 you can achieve this using the Video Screen tool. Right-click on the object and run Attach to Hanging Position and select the first one. By default the closest to the Position load will be attached. The other possibility is right-click the Hanging Position and run the Attach Loads command. A red cross will indicate the load you are about to attach. Moving one truss should move only the load attached. Quote Link to comment
