JMR
Getting an absolute value of a number in a worksheet
Hi,
I ran into a problem where a component list displays negative numbers for extrude lengths. How to get an absolute value?
I'm posting this here since the thread where I found the solution is eleven years old:
https://forum.vectorworks.net/index.php?/topic/23463-worksheet-function-changing-a-negative-to-a-positive/&tab=comments#comment-110335
Eg. for the length of an extrude, this always returns a positive (absolute) value:
=SQRT(LENGTH*LENGTH)
Brilliant.
Did that solution come from @michaelk? It looks like one of his math major things.
I probably would have used
=IF(Length>=0, Length, Length*-1)
If this is something that you use a lot, it may be possible to write a Worksheet Script that would be called something like  =Runscript('WS_ABS','A2') to return the absolute value of the data in cell A2.  It is too late tonight to figure out the detail, but I think it is doable.
It was someone called CS1, apparently not active since 2013.
Probably others have figured this out too.
Thanks Pat, that's a great idea since the ABS function is not available in the worksheet functions menu.
