cberg Posted April 1, 2019 Share Posted April 1, 2019 Is there a way to stack wall recesses above each other without the wall lines showing up in 2d Plan? I am using wall recesses (reluctantly) for my openings. The wall tool desperately needs improvements!!! Wall.vwx Quote Link to comment
TomKen Posted April 1, 2019 Share Posted April 1, 2019 Place the upper opening on its own class. Then turn off that class. The opening will still show up in 3d views and will be off in the plan view. 1 Quote Link to comment
line-weight Posted April 1, 2019 Share Posted April 1, 2019 1 hour ago, cberg said: Is there a way to stack wall recesses above each other without the wall lines showing up in 2d Plan? I am using wall recesses (reluctantly) for my openings. The wall tool desperately needs improvements!!! Wall.vwx Out of interest why are you using recesses for openings? (Agreed that the wall tool needs lots of improvements) Quote Link to comment
cberg Posted April 1, 2019 Author Share Posted April 1, 2019 I am working with an existing model of a building that was scanned in 3d and developed (by others) in Revit. At this point in the VW Development cycle, Revit imports are not reliable (with lots of incorrect geometry). As a result, most of the model had to be imported as an IFC file, (with a ton of associated 3d Solids Geometry). There has been considerable cleanup to make the model smarter since there are also problems with horizontal section viewports. There is also no way to convert solids to walls. :-( It's easier for me to quickly do work in 3d solids rather than fuss with placing odd shaped windows in walls or dealing with stories and wall height elevations. Quote Link to comment
line-weight Posted April 1, 2019 Share Posted April 1, 2019 Sure, but if you are modelling with solids how come you are using wall recesses? You have my sympathy dealing with this kind of model. Recent projects I've abandoned top/plan and do all my floorplans as horizontal sections to get round some of these issues. There are issues with horizontal sections but I find them less restrictive than trying to make things look right in top/plan. Quote Link to comment
cberg Posted April 1, 2019 Author Share Posted April 1, 2019 I've been trying rebuilding specific areas of the model to make it smarter (aka more parametric). To that effect, I've been rebuilding some of the solids as walls. I'm sure you know that wall recesses can be created by using a 3d polygon and a wall or a 3d solid and a wall. Is there a better way to get an opening? I tried using horizontal section cuts and wound up having other issues. Quote Link to comment
line-weight Posted April 2, 2019 Share Posted April 2, 2019 12 hours ago, cberg said: I've been trying rebuilding specific areas of the model to make it smarter (aka more parametric). To that effect, I've been rebuilding some of the solids as walls. I'm sure you know that wall recesses can be created by using a 3d polygon and a wall or a 3d solid and a wall. Is there a better way to get an opening? I tried using horizontal section cuts and wound up having other issues. Ok, I think I get you. I can see that for non-rectangular openings a recess is probably going to be easier than a window opening. My experience using wall recesses and projections has not been very happy, with them behaving unpredictably so I tend to avoid them, and whenever the wall tool falls short I default to modelling it as a solid. But you may need VW to recognise walls as such. What kind of problems were you having with horizontal section cuts? Quote Link to comment
Benson Shaw Posted April 4, 2019 Share Posted April 4, 2019 Does this discussion of symbols as wall openings help? Includes a great tutorial by @Kevin McAllister -B 1 Quote Link to comment
