As far as I can see the options for adding a "drawing stamp" are
(a) add it one sheet at a time, which means for every single sheet selecting the title block, clicking on 'drawing stamp' in the OIP, waiting for the dialogue to open, ticking 'display drawing stamp', choosing the contents, typing in the custom text if custom text is required, pressing OK.*
(b) add the same stamp to every single title block of that style in the file, by editing the titleblock style.
I can't see a way of adding the same stamp to a selected group of sheets, in one go, in the same sort of way that you can add a revision to a selected group of sheets using the [somewhat confusing process via the] title block manager. Is that right, or have I missed something?
*as an aside, VW designers please note: this whole process is much more time consuming than just doing it manually: making a text object, putting it on top of the title block and then copy&pasting it onto other sheets.
line-weight
7 answers to this question
