gester Posted March 29, 2019 Share Posted March 29, 2019 (edited) hi, for some workshop i'm just adding a custom pset made from a record. the issue is to make a pset field for the wall with the value of all window openings. the window gets a separate custom pset. is there a way to connect those values? i know the records are not that sophisticated as the database reports, but they use style and object data, maybe there's a way to solve this? the window-record.field-value doesn't work in the wall pset... thanks for any clue. rob Edited March 29, 2019 by gester Quote Link to comment
Vectorworks, Inc Employee Mihail Rizov Posted April 1, 2019 Vectorworks, Inc Employee Share Posted April 1, 2019 Hi gester, AFAIU, we need to implement more functions in Data Mapping in order to fulfill your requirements - like, number/area of openings, getting material/material layers. For wall height, please, try object bounds functions. For windows, please, try object parameters RoughOpeningArea/OverallArea/ClearArea (area) and WindowMaterial/WindowFinish (you should provide materials in Windows settings -> Data -> fields 16/17). (record fields are in alphabetical order, because of user requirements) Regards, Mihail Rizov Quote Link to comment
gester Posted April 1, 2019 Author Share Posted April 1, 2019 hi mihail, thanks, i see this, too 😉 as for the bounding box: the trouble is that only recognises carthesian dimensions (x/y/z), so if the wall is horizontal and vertical, the values are different for the length and thickness (they are swapped). i don't even try to think of walls under different angles 😉 polish window is a bit different as the us one, and it doesn't use styles. unfortunately the parametric object parameters' list is very short, way shorter than the us one. but here's another thing: the wall style. i have a style with 3 components that i want to extract in the 'material' pset automatically. everything that the style can understand is the component, the first component. or am i missing the right formula? i've tried with component(x).name, componentx.name, all to no avail. is there a solution for those 3 (different) values? and is there a chance to map a thickness value afterwards in the same data row? i'm gradually getting nuts with it... thanks, rob Quote Link to comment
gester Posted April 2, 2019 Author Share Posted April 2, 2019 i take it back, this with the bounding box. it calculates the values _correctly_, not according to the carthesian system. how about the components' listing? Quote Link to comment
gester Posted April 2, 2019 Author Share Posted April 2, 2019 one more question: how to remove a custom pset (based on record) from the ifc data mapping list completely? the more new records i use for psets, the more messed up the overall list gets... rob Quote Link to comment
Vectorworks, Inc Employee Mihail Rizov Posted April 5, 2019 Vectorworks, Inc Employee Share Posted April 5, 2019 Hi gester, Component functions were made to map component data in one particular workflow, which requires each component to be exported as a separate instance (ExportOptions->Export Separate Instances). So, during the export it returns the component data, based on the currently exported layer. Otherwise, it uses the core component data in the calculations. First, you have to remove the custom pset from Manage Custom Psets (IFC Data dialog) and then you have to be sure that a custom pset is removed from all data mappings. (if even one object uses this custom pset in its IFC Data mapping, then the custom pset will be recreated again) Regards, Mihail Rizov 1 Quote Link to comment
gester Posted April 5, 2019 Author Share Posted April 5, 2019 thanks, mihail, it makes sense 🙂 Quote Link to comment
gester Posted April 5, 2019 Author Share Posted April 5, 2019 ok, 1. the result is the wall not having the components in the model tree (solibri model viewer), but the wall itself is getting all materials listed. i'll have to check if the components list correctly in 5d applications for cost calculations. 2. as a general notice: yesterday i was giving a workshop with somebody showing the ifc data mapping in archicad. the overall impression i've got from the participants was the simplicity of ifc assignment and mapping in vectorworks compared with archicad. of course, if you want to have it in a sophisticated way, the possibility to attach data is more developed in archicad, but it's a steep way to get acquainted with the procedure. you have to grab and insert data in many locations in the software. 3. btw, is there a way to reduce the amount of decimal places in the bounding box's x/y/z values? now i get 6 of them... thanks, rob Quote Link to comment
