reverb
Sketch tool
The help menu in 11.5 indicates the sketch tool is
available under the view pull down menu, yet it does not appear. Where do I find the sketch tool?
bingee, You may have to add it to your workspace. Check the workspace editor if it is not already in the menu.
George - I have downloaded VW 11.5 sucessfully, however, I cannot find the sketch tool you refer to when I follow your suggested path. I have the Industry package and following View to Rendering; there is not a Sketch option listed anywhere. Any suggestions? - Cary
You may need to go to: FILE>WORKSPACE>WORKSPACE EDITOR. Once you are there, you locate the item you want to add and then drag it from the left-hand column (of available menu items) into the right-hand column (of current workspace menu items). Hope that helps...
