reverb Posted March 18, 2005 Share Posted March 18, 2005 The help menu in 11.5 indicates the sketch tool is available under the view pull down menu, yet it does not appear. Where do I find the sketch tool? Quote Link to comment
G_Hannigan Posted March 18, 2005 Share Posted March 18, 2005 If you have one of the "Industry" packages, it will be: View Rendering Sketch Sketch Options George Quote Link to comment
Kevin Posted March 18, 2005 Share Posted March 18, 2005 bingee, You may have to add it to your workspace. Check the workspace editor if it is not already in the menu. Quote Link to comment
caryme Posted March 20, 2005 Share Posted March 20, 2005 George - I have downloaded VW 11.5 sucessfully, however, I cannot find the sketch tool you refer to when I follow your suggested path. I have the Industry package and following View to Rendering; there is not a Sketch option listed anywhere. Any suggestions? - Cary Quote Link to comment
CipesDesign Posted March 20, 2005 Share Posted March 20, 2005 You may need to go to: FILE>WORKSPACE>WORKSPACE EDITOR. Once you are there, you locate the item you want to add and then drag it from the left-hand column (of available menu items) into the right-hand column (of current workspace menu items). Hope that helps... Quote Link to comment
