marksw Posted March 19, 2005 Share Posted March 19, 2005 I just upgraded to 11.5 from 11 and now seem to have to edit the width and height of an object that I have extruded only in the objects shape window, as an unextruded element. I used to be able to, in plan view, change the objects 3 dimensions in the info pallet and now this does not take the dimension change....what happened? As and example, a rectangle exturded to 3" viewed in plan, I now have to double click to object to get to the shape to change the size lest the extruded dimension...(this sounds more confusing that it is) This is adding extra steps I would like to avoid each time I want ot change the size of a object. Running OSX 10.3.7 Quote Link to comment
Gerard Jonker Posted March 19, 2005 Share Posted March 19, 2005 I have two machines next to each other, one running 11.0.1 the other 11.5 I can't reproduce your problem on them. The usual remedies perhaps? Zap the PRAM (alt+apple+P+R at start up) Repair permissions Keep your mac running overnight Succes, Gerard Quote Link to comment
Denis O'Reilly Posted March 21, 2005 Share Posted March 21, 2005 I too can confirm this is happening me, and also the document preferences window will not open. Quote Link to comment
Kevin Posted March 21, 2005 Share Posted March 21, 2005 Running 11.5.0 on OS10.3.8. All 3 dimensions of the extrude are editable in the OIP from both plan and isometric views. Quote Link to comment
Denis O'Reilly Posted March 21, 2005 Share Posted March 21, 2005 Might I just add, this is an intermittent issue, as of yet its happening on occasion in new drawings and also in existing vw 11.1 drawings, I am running Os 10 .3.8 Unfortunatly its that bad I have to revert back to VW 11.1 for my business...... Quote Link to comment
Kevin Posted March 21, 2005 Share Posted March 21, 2005 As Gerard points out, be sure to run Disk Utility and repair permissions. Anytime I add or update a program I run the utility before and after the install or upgrade. No guarantees, but a good place to start. Quote Link to comment
Adam E Posted March 22, 2005 Share Posted March 22, 2005 This is happening to me too. On a g5 running OS 10.3.8. I can't edit extrusions in the OIP. Quote Link to comment
