Steven Kenzer Posted March 26, 2019 Share Posted March 26, 2019 Can someone explain to me why some odd rendering sequence is occurring? I took File A and "saved as" File B. Then deleted the current vanity and copy and pasted in a different one. When I got to render File B, the vanity that was in File A returns. I've purged the file, rebooted, in 2d all looks fine but then that first vanity keeps showing up each time the file is rendering. The attached screenshot gives you a sense of what's going on. The rendering starts out fine (white one in the screenshot) but as it progresses, the wood one appears. It's as if it's stuck in some VW cache..or something like that. As always, thanks for any help/advice on this. Quote Link to comment
Matt Overton Posted March 27, 2019 Share Posted March 27, 2019 If the render is in a viewport sometimes you need to force the geometry to reset. Switching off the layer the vanity is in, render, then switch it on again usually does the trick. 1 Quote Link to comment
Steven Kenzer Posted March 27, 2019 Author Share Posted March 27, 2019 Thanks, Matt. That worked. Layer off/Layer on/ All good. Much appreciated. Quote Link to comment
