I just started in 2019, and stumbled across the feature with the ability to group fields in label legends, which is amazing. I've been wanting this forever, especially with the ability to add text such as a universe/address divider. And, they behave nicely with the "adjust flipped text" option.
However, the grouped fields do not appear to behave as expected as par as position goes. Looking at the attached image, you'll see that the ungrouped fields move as expected to hug the bottom of the fixture (but don't work right when flipped). The grouped one flips text as desired, but stays in the same location relative to center no matter how big the fixture is. I assume this is not how it should function.
It would also be great if the group could auto-center so that the label was always centered on the center point of the group, no matter how wide it becomes. For instance, if your universe is 4, the group will be a different width than if it's 24, and the label will be slightly offset. This is far less important than the position.
Hopefully, this can be fixed in the next service pack. I'm thinking I'll deal with the position for now.
SamIWas
0 answers to this question
