Georeferencing in China
rowbear97
1 answer to this question
On 3/22/2019 at 11:10 AM, rowbear97 said:
My client has an office in China and evidently use a different project or at least one offset from WGS-84. Would it be possible to get some guidance or an update that will add China to the list under Plate Carree, Ellipsoid  GCJ-02 coordinate system?
Vectorworks supports the EPSG catalog, so you may want to ask them the EPSG code of their coordinate system (assuming there is one). You can then look this up through the coordinate settings in the projection dialog and it should then load necessary projection information.
