Projector Weight Field Calculation
Howdy Team,
I am looking at the video screen tool and have realised that the weight field is populated globally by the plug-in parameters, meaning that all projectors will display at the weight set in the plug-in manager fields ProjWeightLB and ProjWeightKG within the video screen tool. Is there a way to set the weight to vary based on the projector model selected?
Secondly, when using multiple projectors (Stacked or side-by-side) the weight of the projector shown in the "include in calculations" field is not doubled, should that not be updating?
Thank you so much for your time!
Guest Yordan Kostadinov
Hi Hayden,
When using Stacked or Side-by-side projectors in Vectorworks 2019 SP3, the weight will automatically double and divide when you change the settings. Both projectors are considered a single load in Braceworks and are controlled by single Load Information block.
Yordan
