JMR Posted March 19, 2019 Share Posted March 19, 2019 Hi all, I needed to reset my space objects in order to show changed custom data in the tags. It takes a long time to reset everything, is there a way to reset only one type of objects? As in select similar - space object - reset plug-ins Thanks Quote Link to comment
Marionette Maven Marissa Farrell Posted March 19, 2019 Marionette Maven Share Posted March 19, 2019 You could create a script in your Resource Manager (set the language to Python Script from the drop down) and place this code in it: def ResetThem(h): vs.ResetObject(h) vs.ForEachObject( ResetThem, "SEL = True" ); This script will reset all selected objects. Another option is to create a set of scripts that reset objects based on criteria, for example, the following script will reset all Space objects: def ResetThem(h): vs.ResetObject(h) vs.ForEachObject( ResetThem, "((PON='Space'))" ) You can also add these scripts as menu commands using the Plug In Manager. 1 Quote Link to comment
JMR Posted March 19, 2019 Author Share Posted March 19, 2019 Excellent, thank you very much! (That functionality could be put into a submenu of the reset plug-ins menu, in stock VW...no? Would be very useful IMHO.) Quote Link to comment
