Well, I don't know where you're looking. If you're simply rendering on a Design Layer you can go to the Navigation palette, Classes tab and turn the class off. Similarly you can go to Tools>Organization and the Classes tab and turn off there.
If you're woking in a SLVP, you have to select the SLVP and then click the Classes button in the OIP and turn the class off in there.
When you insert a truss object with the insert truss tool and choose a symbol from the library, VWX adds several classes. Amongst them are Rigging>Truss>Simplified ad Rigging>Truss>Truss.
The simplified class is a really simple box geometry meant for speedy navigation. The Truss geometry is in the Truss>Truss class. Turn that on and turn the Truss>Simplified off.
You can also import the truss intl your drawing and from your resource manager select the truss and edit the 2d and 3d components by just selecting the box surrounding them and deleting.  This will also allow you to purge the unecessary classes since there will be no data in them.
  • 1 month later...
