Victor S
Custom shaped gable
Hi Guys I have a heritage project with a custom shaped gable and need some help please.
I have created a gable as per attached, using a simple 2d poly line (and extruding by 300mm in top/plan).
I now need to rotate the whole project into the elevation plane, but struggle to find the command. Any suggestions?
Also is there any way to rotate a object which was created with a slab/floor tool?
Gable.pdf
Hi Victor,
I assume you first drew this in Top/Plan view...now you need to change the view and rotate the object...
If it's 2D or an extrude from 2D, you can simply go to a side view and use the Rotate command to "stand it up"
Slabs and floors CANNOT be rotated.
However, you CAN slope a slab using the Slab Drainage tool
Wes
