John Meunier
Database CAPITALS
Is there the ability to make a VW 2019 file ALL CAPS? Including databases and text styles.
So far my workaround has been to manually type in CAPS, but the database header has got me stumped.
I must be missing something. Any help is appreciated.
Thank you
@John Meunier
Not that I am aware of...but this is something, along with general Text handling, that VW desperately needs. ALL CAPS is industry standard for construction documents and has been forever. Needs to be implemented ASAP!
19 hours ago, ericjhberg said:
@John Meunier
@ericjhberg Really. Just because that's the way it has been doesn't mean that it should always be! ;-)!
Fair enough. I don't disagree. However, you fail to convince me that it, at the very least, shouldn't be an option.
  • Laugh 1
Thank you
There is no native way to do it. But you could with a script.
1. Create a script in your file name it 'WS_ALL_CAPS' . (When it asks you to create a palette, just name the palette whatever you want, something like 'WS Scripts' will suffice.
2. When the script dialog box pops up, change the language to Python.
3. Use the code below in your script:
orignal_str = vs.WSScript_GetPrmStr(0)
vs.WSScript_SetResStr(orignal_str.upper())
4. Now back in your worksheet, select the cell you want capitalized. Enter this into the formula bar:
=RUNSCRIPT('WS_ALL_CAPS', 'Existing Tree'.'ActionComment')
5. Recalculate Active Worksheet
Edited by twk
Hi @John Meunier,
Looks like a glitch in the matrix..
- Any other formula added to that glitching cell doesn't work.
- If I copy the formula out, then replace it with the cell's formula next to it. The worksheet starts to function again.
- Now I can copy back in the first formula I had (or you wrote), and it recalculates fine.
On 3/13/2019 at 1:39 AM, ericjhberg said:
@John Meunier
I'm sure that this is already somewhere deep down inside vectorworks. It just seems to be hidden for now.
When you look at the Title Block - Drawing Stamp options there's a check box for 'Use ALL CAPS'.
We just need them to spread this function to the rest of the text.
