Hans-Olav Posted March 12, 2019 Share Posted March 12, 2019 I remember the discussion from time to time about spots and dirt in ceilings but can't remember any solutions or how to minimise it. is it a specific setting or something to do with the lighting? Quote Link to comment
RussU Posted March 12, 2019 Share Posted March 12, 2019 While I'm not an expoert in RW, this looks like a global illumination issue, and a light bounce issue. Undersampling secondary bounces. First thing to check is that there's no "light leaks" in the model, and the geometry all touches nicely, but then up your levels for "Indirect Lighting" and "Environment Lighting". Raising the Bounces / Max Reflections might help too. Can you post a screen grab of your current RW options? Quote Link to comment
Hans-Olav Posted March 12, 2019 Author Share Posted March 12, 2019 Thanks for the post here are my settings Tha Quote Link to comment
Hans-Olav Posted March 12, 2019 Author Share Posted March 12, 2019 Hi "Indirect Lighting" and "Environment Lighting" is maxed out. Still dirty ceilings Quote Link to comment
RGyori Posted March 12, 2019 Share Posted March 12, 2019 You might check out this earlier discussion... HTH 2 Quote Link to comment
Hans-Olav Posted March 12, 2019 Author Share Posted March 12, 2019 @RGyori Thanks That was the discussion I was looking for Quote Link to comment
Phil hunt Posted March 13, 2019 Share Posted March 13, 2019 Try the settings all on high and knock back the strength of the ambient occlusion Quote Link to comment
Phil hunt Posted March 13, 2019 Share Posted March 13, 2019 Hans try turning of sky interior you seem to be picking up some sky colours in your render Quote Link to comment
Phil hunt Posted March 13, 2019 Share Posted March 13, 2019 Finally didn't know you could have 16 bounces turn it down to 8 1 Quote Link to comment
Popular Post Hans-Olav Posted March 13, 2019 Author Popular Post Share Posted March 13, 2019 Here are the results after some more testing 4 1 Quote Link to comment
RGyori Posted March 13, 2019 Share Posted March 13, 2019 @Hans-Olav Glad it worked out for you... and nicely done! Quote Link to comment
Phil hunt Posted March 14, 2019 Share Posted March 14, 2019 Hans what settings did you finally use. ? Quote Link to comment
Hans-Olav Posted March 14, 2019 Author Share Posted March 14, 2019 Here is my settings 59 minutes ago, Phil hunt said: Hans what settings did you finally use. ? p2 interior-ny-2 is the top most picture @Phil hunt I was also tweaking the textures. the curtain is different between the two rendering the top most is just plain transparency the other one uses a image map for transparency 1 Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted March 14, 2019 Vectorworks, Inc Employee Share Posted March 14, 2019 Note how his reflections are set to 6, this is WAY higher than I have recommended in the past since it doesnt affect the reflectivity appearance all that much beyond 3. Its looking more and more that this option is also controlling how many times light is allowed to reflect, which is supposed to be also controlled by indirect bounces, or at least thats what I had thought. I'm going to be confirming and filing for separate control of this for more efficient renderings. 3 Quote Link to comment
markdd Posted March 14, 2019 Share Posted March 14, 2019 56 minutes ago, Jim Wilson said: Note how his reflections are set to 6, this is WAY higher than I have recommended in the past since it doesnt affect the reflectivity appearance all that much beyond 3. Its looking more and more that this option is also controlling how many times light is allowed to reflect, which is supposed to be also controlled by indirect bounces, or at least thats what I had thought. I'm going to be confirming and filing for separate control of this for more efficient renderings. It would be really helpful to get some clarification from the engineers about this.... 3 Quote Link to comment
