Usually I share almost all my projects with architecs that use AutoCAD, but during the past years I havent found a satisfactiry solution exporting from VW to AutoCAD. The results always is a viewport or model that are absolutely unmanagable due size, slowiness and unresponsive in AutoCAD. I'm sharing the original file that I must convert to DWG. Any help would be appreciated! Because I have received so many complains from the companies wich I work.Thank you!
Rodolfo Stoltzmann
Hi all:
Paisajismo Edificio Colón (Sub, 1º y 2º Piso) Enero 2018.vwx
5 answers to this question
