SimonBarrington Posted March 11, 2019 Share Posted March 11, 2019 I know I have probably done something really dumb, but I can't for the life of me work out what... The Hoist display is is going me a black box instead of the hoist label... image attached Quote Link to comment
mjm Posted March 11, 2019 Share Posted March 11, 2019 1 hour ago, SimonBarrington said: I know I have probably done something really dumb, but I can't for the life of me work out what... The Hoist display is is going me a black box instead of the hoist label... image attached Looks to me like the solid fill color may be black, like the pen color… Quote Link to comment
SimonBarrington Posted March 11, 2019 Author Share Posted March 11, 2019 It is, but I don't know how it changed to this. I have figured out how to change the display back to how it should be 1 unit at a time, but with 196 hoists... its going to take a fair while! Quote Link to comment
mjm Posted March 12, 2019 Share Posted March 12, 2019 (edited) Can you not select all hoists and etc the Pen and Fill of all of them at once? Edited March 12, 2019 by mjm Spelling Quote Link to comment
SimonBarrington Posted March 12, 2019 Author Share Posted March 12, 2019 Thein lies another problem. If you go in and edit the 2 component to change the fill (which is the way to do it, and you can only do 1 at a time), it seems to lose the link to the hoist data... and the point is then useless in terms of data on the drawing. What I am most confused about is why that fill has suddenly started appearing, and even if I put a new hoist in, the fill is there. I've looked through class properties and all sorts... its a bit of mystery! Quote Link to comment
mjm Posted March 12, 2019 Share Posted March 12, 2019 (edited) 10 minutes ago, SimonBarrington said: Thein lies another problem. If you go in and edit the 2 component to change the fill (which is the way to do it, and you can only do 1 at a time), it seems to lose the link to the hoist data... and the point is then useless in terms of data on the drawing. What I am most confused about is why that fill has suddenly started appearing, and even if I put a new hoist in, the fill is there. I've looked through class properties and all sorts... its a bit of mystery! And your Pen Fill settings look like the screen shot when placing hoists? Edited March 12, 2019 by mjm Quote Link to comment
scottmoore Posted March 13, 2019 Share Posted March 13, 2019 Is there a specific class the hoists use for text and, if so, is the class set to black fill and you either have class fill color selected in the attributes palette or if you edit the class, is it set to automatically use pen and fill at creation? That is a run-on sentence if ever there was one. The same might apply to whatever class you are using to place your hoists. If the attributes are set to “use at creation” in the class edit dialogue, it will use those attributes regardless of what you have selected in the attributes palette. Quote Link to comment
SimonBarrington Posted March 13, 2019 Author Share Posted March 13, 2019 I'm happy to report a resolution on this.. and it wasn't what I was expecting. @mjm ...I had the fill set to no fill. When looked at the properties of the hoists with the problem, they also ad the fill set to "no fill". So on the surface of things, this didn't appear to be the problem. However, when I set the fill to solid and white, all the problems seem to have gone away. @scottmoore...I had tried all the options you suggested, to no avail, but they were the obvious solutions to look for! Thanks both 1 Quote Link to comment
mjm Posted March 13, 2019 Share Posted March 13, 2019 8 hours ago, SimonBarrington said: I'm happy to report a resolution on this.. and it wasn't what I was expecting. @mjm ...I had the fill set to no fill. When looked at the properties of the hoists with the problem, they also ad the fill set to "no fill". So on the surface of things, this didn't appear to be the problem. However, when I set the fill to solid and white, all the problems seem to have gone away. @scottmoore...I had tried all the options you suggested, to no avail, but they were the obvious solutions to look for! Thanks both Thanks for the update. The most concerning element of your initial report was that, in taking corrective action hoist data was damaged. Hopefully that ended up being not true. Quote Link to comment
scottmoore Posted March 13, 2019 Share Posted March 13, 2019 Sorry I was not more help. I’ve not used the Spotlight hoist tool. Quote Link to comment
