Robert NewBarn
Dimensions causing crashes
When I add dimensions in annotations mode in Viewport, it crashes (or massively slows) my programme. I use VW2019 SP2.
Any advice? - is this unusual??
7 answers to this question
Get in touch with tech@vectorworks.net directly for this, especially if you are using macOS 10.14 Mojave.
It can be, if you are able to alleviate it by doing the very strange troubleshooting step of undocking your Object Info palette and leaving it simply undocked, then this is a known bug that will be corrected in 2019 SP3. I believe however that there are other steps support will want to perform on that machine as well.
Well I have to admit I was sceptical at your suggestion - my Object Info palette is never really docked anyway.  But I pushed it right outside the VW screen area ... and it worked!
(having previously wasted a tonne of time updating the software, etc with no effect)
Thanks Jim!
Similar problem here (Vectorworks hangs for five minutes when a dimension is selected - this is in the drawing layer), but sadly undocking the Info palette doesn't help. [VW2019 SP2 and Mojave 10.14.3]
Undocking the palette only works sporadically for me - and when I save/close the file I get the beachball... sigh.
Then most likely this issue is the Mojave bug that we were able to put a workaround in for for SP3. No public date for it yet, but should be within the next few weeks.
