Joel-L Posted March 9, 2019 Share Posted March 9, 2019 Hi All, Is there a way to choose in vectorworks what parts of set is converted into a single meshshape when importing to vision? I'm having a problem where some of my objects are being converted into one meshshape, but I need to rotate individual objects and can't do it while its 'grouped'. Or is there a way that your class design and class layers make themselves their own structure e.g. If I had a two design layers which referenced the same class, the file structure would be split down as shown below? Design layer 1 > Class 1 > 1, Design Layer 2 > Class 1 > 1 Quote Link to comment
Kevin Allen Posted March 9, 2019 Share Posted March 9, 2019 If I understand what you're asking, you need to do and export ESC or MVR with just the objects you want visible. 1 Quote Link to comment
Joel-L Posted March 9, 2019 Author Share Posted March 9, 2019 @Kevin Allen That's not a bad shout! I hadn't thought of doing that. Quote Link to comment
Gaspar Potocnik Posted March 10, 2019 Share Posted March 10, 2019 One option is to export as separate .esc (which is what I usually use) but what happens is VW exports everything that has the same texture together or if it has no texture then everything with the same color fill. So assigning different textures or color fills make separate meshes in Vision. Quote Link to comment
Joel-L Posted March 11, 2019 Author Share Posted March 11, 2019 @Gaspar Potocnik Ah okay! I didn't realise that how it groups things together. Thanks for letting me know 🙂 Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted March 20, 2019 Vectorworks, Inc Employee Share Posted March 20, 2019 With Vision 2019 SP3, MVR support has been greatly enhanced and is the new recommended workflow for getting from VW to Vision. MVR will not group objects in this way 😉 Quote Link to comment
