Create Mitre on Polygon
IJSSEL
Is it possible to change the Angle of one or more sides of a 2D Rectangular Polygon.
I'm trying to create a Mitre ( 45º).
Steps :  1- Network creates a rectangle ( 20x600mm). 2-- Change it into a Polygon. 3-- Create a Mitre on the small side ( 20mm).
Appreciate idea's.
Regards
  • Marionette Maven
Here's the beginning of my trapezoid node - there is no error handling in this version, so you may end up with results you don't want if your dimensions aren't reasonable.
My later improvements list:
  • Allow orientation defined in the node
  • Allow an origin point
  • Allow user to flip which side is shorter
  • Allow user to define an angle for the trapezoid
Marionette_trapezoid_MFarrell.vwx
Yes, this is great, thanks a lot.
I'm looking forward to the improvements. The first two on your "list" are (in my case) the most important ones. I'm now playing with the rotation tool (after I Extrude the 2D Trapezoid) to get it the way I want.
Best regards
