Avi Orr Posted March 5, 2019 Share Posted March 5, 2019 I'm Trying to export a Sheet Layer as a DWFx and the resulting file is much shorter then the Sheet. The Sheet is about 6300mm long and the DWFx comes out about a 1200mm long with most of the iformation missing. Trying to export the Design Layer directly doesnt help, nor does exporting a different DWF type. Quote Link to comment
0 Vectorworks, Inc Employee Nina Ivanova Posted March 5, 2019 Vectorworks, Inc Employee Share Posted March 5, 2019 Are you using a custom sheet size? There are predefined paper sizes, used by the third-party DWG/DXF, DWF and DWFx writing libraries. When a custom sheet size is used, the most appropriate predefined paper size is chosen. Seems that there is no good approximation for the 6300 mm long sheet. Exporting to a different DWF type will not work because of the already mentioned reason. Exporting from a Design layer should show all the objects. If you want, you could send the file, so that I can confirm the cases. Quote Link to comment
Avi Orr
1 answer to this question
