Bruno Sá Posted March 4, 2019 Share Posted March 4, 2019 Hi everybody! Does anyone know if there's possible to link a text in the title block with the file location? Thanks! Bruno. Quote Link to comment
markdd Posted March 4, 2019 Share Posted March 4, 2019 Yes. You need to investigate the Hyperlink Tool. It should be in the Dims/Notes toolset. You can set it to follow a file path. 1 Quote Link to comment
Bruno Sá Posted March 4, 2019 Author Share Posted March 4, 2019 Hi Mark! I did it, but don't know why it didn't work! I'll try again... Thanks Quote Link to comment
markdd Posted March 4, 2019 Share Posted March 4, 2019 I think you need to press Command and click when you are in the actual vwx file. If you have generated a pdf then it works like a normal hyperlink. any good? Quote Link to comment
Bruno Sá Posted March 4, 2019 Author Share Posted March 4, 2019 It gives me this error... Quote Link to comment
markdd Posted March 4, 2019 Share Posted March 4, 2019 Mmm. Not sure. Do have access to the library file where the symbols are stored? Quote Link to comment
Bruno Sá Posted March 4, 2019 Author Share Posted March 4, 2019 yes, but wich library contain this symbol? Quote Link to comment
markdd Posted March 4, 2019 Share Posted March 4, 2019 (edited) In the Vectorworks library under libraries/defaults/hyperlink/default Hyperlink.vwx Edited March 4, 2019 by markdd Quote Link to comment
Bruno Sá Posted March 5, 2019 Author Share Posted March 5, 2019 I'll check it out! Give you feedback later! Thanks again! Quote Link to comment
Pat Stanford Posted March 6, 2019 Share Posted March 6, 2019 @Bruno SáAre you actually trying to make a hyperlink from the file to itself? Or do you just want to display the file name as part of the title block? 1 Quote Link to comment
Bruno Sá Posted March 6, 2019 Author Share Posted March 6, 2019 @Pat Stanford You're right! What I need is to show the path to the file location at the title block. Do you know how to do it? Thank's a lot! Bruno. Quote Link to comment
Pat Stanford Posted March 6, 2019 Share Posted March 6, 2019 Kind of. I don't have time right now to find exact steps so hopefully this will be enough. With an Unstyled title block, from the OIP click he Edit Title Block Layout button. Choose of place a text block where you want the file name to appear. It should say Text in Title Block at the top of the OIP. At the bottom of the OIP under Title Block Data set a Data Type of Link Value and a Parameter of Project Data:File Name. Exit the Title Block Layout. You can then save the edited Title Block as a new Style for future use. You may be able to edit a Style of Title Block from the Resource Browser, but I am not certain. 1 Quote Link to comment
Bruno Sá Posted March 6, 2019 Author Share Posted March 6, 2019 Great Pat! I'll check it out and give you feedback later! Thanks again! Quote Link to comment
Markvl Posted March 7, 2019 Share Posted March 7, 2019 (edited) I guess I may be looking for the same thing or not. I'd simply like to have a piece of text that upon inserting it will show the current file path or that it is part of a custom titleblock. I've been digging but not finding anything. Is it attained by some kind of text string in a Record other than P_File Name? Edited March 7, 2019 by Markvl 1 Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted March 8, 2019 Vectorworks, Inc Employee Share Posted March 8, 2019 This data can be added to your Title block or if you want to use it randomly anywhere the Data Tag will be the tool for this 1 Quote Link to comment
Markvl Posted March 8, 2019 Share Posted March 8, 2019 @JuanCarlos is this for v2019? If so what about v2017? 1 Quote Link to comment
rDesign Posted March 8, 2019 Share Posted March 8, 2019 (edited) Prior to 2019, you would use the ‘Data Stamp’ tool from the Dims/Notes toolset to add a text object that shows the current file name. Vw2017 Help File :: Creating Data Stamps Edited March 8, 2019 by rDesign Quote Link to comment
Markvl Posted March 8, 2019 Share Posted March 8, 2019 Well got it figured out on v2019 and ya I know about the "Data Stamp" but is there anyway to get a long version as shown in the pic attached in v2017? Can I in some way change (customize) the output of that Data Stamp? @rDesign, @JuanCarlos 1 Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted March 8, 2019 Vectorworks, Inc Employee Share Posted March 8, 2019 Yes you can customize the Data Stamp to show just the file address, checking for file path 1 Quote Link to comment
Markvl Posted March 8, 2019 Share Posted March 8, 2019 Perhaps I'm being misunderstood. I've figured out how this works in v2019. In v2017 the data stamp only shows the file name not the file path. Yes I understand how I can turn of all other info except the file name. Its the file path that I'm interested in for v2017. If there is a way how do I do it? 1 Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted March 8, 2019 Vectorworks, Inc Employee Share Posted March 8, 2019 There is a call (GetFPathName) but my scripting capabilities have gone south, maybe Pat can chip in @Pat Stanford 1 Quote Link to comment
Pat Stanford Posted March 10, 2019 Share Posted March 10, 2019 In 2017 there is no easy way to have a text block that will automatically update when the file name changes. Relatively easy to make a semi-static text block that could be updated by a script or a PIO that could be regenerated, but you would need to manually run the script or regenerate the PIO when the file name changes. 1 Quote Link to comment
