rvanhees Posted March 4, 2019 Share Posted March 4, 2019 Hello, Is there a way to make a report of only the viewport? Now the report gets everything of the design. Quote Link to comment
Pat Stanford Posted March 10, 2019 Share Posted March 10, 2019 Try this: Create an object the same size as your Viewport Crop and place it on a design layer in the same position as your crop. Give it a name in the OIP and place it in a new class. Edit your Report Criteria to add a new criteria of LOCATION IS 'Name you gave the object' You may also need to add a criteria to specify the Design Layer you are interested in. You can then set the class of the object used in the LOCATION to Invisble and it should still limit the report. Ask again if you need more help. Quote Link to comment
