GregB
VW 2019 SP2 crash during autosave
Hello All. I have experienced several program crashes last week. No spinning ball , no warning, program  just vanished from screen after split of second hesitation. All I did meanwhile, was using search box to find a specific class. After crash I went to folder which keeps backup files and each time back up was saved exactly same hour when crash happened. My backup autosave interval is 5 minutes. It might be coincidence but I suspect that crashing is somehow related to auto saving.
Did anyone else had similar problem?
It is a brand new computer just built a week ago. I am using VW 2019 Architect SP2. Software and Backups are on Partition 'C' (SSD) , project files on separate hard drive (SSD). I attached DxDiag for your reference.
DxDiag.txt
5 answers to this question
9 out of 10 of my crashes are right at the autosave moment. I've noticed this repeatedly throughout vw2019. It's not during every autosave, as I have it set to 4 minutes, but quite often the program crash is right in the same minute at the save file.
I always recommend setting autosave to number of operations instead of an amount of time for this reason. Quite a few versions ago there was an issue with crashing and autosave when using time...
Kevin
@Kevin it is a very good point. I have not been aware of switching autosave to number of operations. However it seems to be just a temporary walk around.
Interesting is that previously I have worked for several weeks on another machine: Dell 7710 mobile workstation and it has never happened to me. Just trying to figure out if any setting could prevent it but still no clue. For now I have reduced speed of RAM memory to standard 2133Mhz (was overclocked to 3200) and will test it for couple more days.
@Kevin McAllister do you have any recommendations on how many operations between autosaves? I've filled my swear jar for the day with random autosave crashes...
I have actually turned off Autosave completely recently just to see if it solves the problem but it doesn't.
Crashes seems to be unrelated to Autosave. VW still crashes a lot randomly!
