rvanhees Posted March 2, 2019 Share Posted March 2, 2019 Hello, I made a floor in VW2019 for a stand. From Top/Plan: 1) Rectangle tool 2) spotlight- architactual - floor 3) tab render - texture - wood The problem is het puts the texture under see picture 3 I tried flip / rotate etc ... Is there a easy way, or what did i do wrong? Quote Link to comment
JBenghiat Posted March 2, 2019 Share Posted March 2, 2019 In your texture options, you have the part selected as overall. You can have separate selections for top, bottom, and sides. Quote Link to comment
Kevin Allen Posted March 2, 2019 Share Posted March 2, 2019 The Floor is a hybrid object, you're seeing the 2D part which cannot be textured. You can fill it with a hatch (to shows lines) or an image fill which might give you the results it sounds like you want. Quote Link to comment
rvanhees Posted March 2, 2019 Author Share Posted March 2, 2019 @JBenghiat Hi Tnx for the answer, it works. Quote Link to comment
