Zachary Hubbard Posted March 1, 2019 Share Posted March 1, 2019 How do you change the order of the instruments in the instrument schedule? Or is there a way to sort the list? Quote Link to comment
Pat Stanford Posted March 10, 2019 Share Posted March 10, 2019 In the worksheet edit mode, make sure that Database Headers is checked in the Worksheet View menu. Select the column you want to sort by and click on the black disclosure triangle and select Sort: as either ascending or decending. You can sort by multiple columns at once, but need to start with the least important and work to the final desired result. Quote Link to comment
