Twisted multiple extrude
RussU
Hi all,
I'm scratching my head on this one... Two simple polylines to multiple extrude.
I want to go from bottom one to top one, smoothly. So Multiple extrude is the way forward.
So I put them on the same plane and execute the command. I get a twist.
The vertex count is the same in both profiles, and the direction of draw is the same, but it does seem like that the "start" vertext is in a differenct place. In other packages you'd choose the vertext and then "make first" on both profiles, to get the right ones to line up. But I can't work out how to in VW.
Have tried a convert to nurbs and do a no-rail loft, and I get the same result.
Any clues please?
Edited by RussU
6 answers to this question
