Hole in a Stage plug
Dendecko
I have a Stage plug built that I need to put a turntable inside.  Is it possible to put a hole inside of a stage plug from the stage plug tool?  I have placed the cutouts in the 2d components and made it part of the polyline path but neither placed holes in the 3d view of the plug.  I also tried to create a solid subtraction with a cylinder to create the hole to no avail.  Does anyone know if this is possible?
Hello,
I have made an enhancement request that the contextual menu item 'Create Objects from Shapes' have an option to create a Stage Plug. This would be a huge time saver and allow the user the benefits of the Stage Plug versus truncated Stage Decks that you get when running the 'Create Stage' command. For example in the creation of a revolve like you.
Cheers,
Peter
  • Like 3
