  • 1
Rendered viewport turns black
Klaus Koch
Hi,
we can not longer render vieports with vwx2019 SP2.
The process is normal, the image is created and becomes black at the end.
Graphics drivers are up-to-date, even with old drivers tested, is also turns black at the end.
In VWX 2018 on the same machine and with the same settings it runs with correctly.
Attached 2 screenshots during rendering and a vwx file
test render vieport.vwx
4 answers to this question
6 hours ago, klabeko said:
Hi Selin, changing the default compression to PNG is the solution!
You helped me a lot, thank you very much!!!
Klaus
No problem, apologies for the hold up. JPEGs will be fixed in the next SP.
