I can't work out what's going on here. The attached file has a wall object, and three 'grid plane' objects (these are groups containing 3d polygons). The wall should be positioned with its outer face aligned with the vertical grid plane, and its top and bottom aligned with the horizontal grid planes. When viewed in wireframe, all seems to be ok. But in section it seems to be misaligned by 1mm in each direction...why?
(You can use the saved views in the file to see this)
line-weight
VWalignment.vwx
3 answers to this question
