3D Flyover of 2D objects
abshapi
I have a file of my venue that I've been working with.   When doing a 3D flyover of the drawing, everything on one layer, whether 2D or 3D, will rotate around just like the 3D objects.   However, everything on other layers, only the 3D objects will rotate around.   The 2D objects will stay or if they're on a non-active layer, they will just disappear.   How do I make it so those 2D objects will rotate around as well.
2 answers to this question
Two things to look at:
1.  Make sure your 2D geometry or text or whatever is on the layer plane and not on the screen plane.  Look in the OIP at the top.  If the object is a group you need to go inside the group and change the layer/screen plane settings.
2.  There is a setting for Unified View to show or not show screen plane objects in the active layer or other layers.
