Mickey Posted February 19, 2019 Share Posted February 19, 2019 Vectorworks Viewer of VV is a handy tool https://www.vectorworks.net/support/downloads/vectorworks-file-viewer I'm looking at putting together s tablet PC (Surface Pro) for meetings. Since moving last summer I find I have to ride my motorcycle into the city often for meetings, and I bring my whole mobile CAD rig. It's a bit tiresome dragging all the hardware around with me. Most of the time I don't make changes in the active file, but we just look at things, and take notes. In my mind I can use a Surface pro as a mini PC for viewing VW files I have stored on a cloud drive, and reduce the weight on my back. However: There's no specs' on the website. I'd hate to think I've got this great solution only to find my tablet PC is a sorry slab like my Samsung phone. Anyone? Quote Link to comment
Sam Lunetta Posted February 19, 2019 Share Posted February 19, 2019 I have a Surface Pro-2 and run VW19 on it. In Open GL it works OK. I would not try to do a full Render on it... Quote Link to comment
Guest Paulo Ferrari Posted April 29, 2019 Share Posted April 29, 2019 Hi Mickey, Depends, this projects that you will open in Vectorworks Viewer, it's in 3D or 2D? I'll waiting your reply. Regards, Paulo Renan Ferrari. Quote Link to comment
Mickey Posted April 30, 2019 Author Share Posted April 30, 2019 On 4/29/2019 at 8:06 AM, Paulo Ferrari said: Hi Mickey, Depends, this projects that you will open in Vectorworks Viewer, it's in 3D or 2D? I'll waiting your reply. Regards, Paulo Renan Ferrari. The files are all types. VW viewer should have a standard hardware spec the same way Vectoworks does. Somewhere there should be a minimum, and performance spec for viewer, and I can't find anything. Quote Link to comment
Nicolas Goutte Posted April 30, 2019 Share Posted April 30, 2019 (edited) 13 minutes ago, Mickey said: VW viewer should have a standard hardware spec the same way Vectoworks does. Somewhere there should be a minimum, and performance spec for viewer, and I can't find anything. I suppose that there are no separate hardware specification, as the viewer comes from the same code base, as far as I know. Therefore I would assume that it has similar needs. Edited April 30, 2019 by Nicolas Goutte Quote Link to comment
Guest Paulo Ferrari Posted April 30, 2019 Share Posted April 30, 2019 HI Mickey, Thanks. In this way, I recommend a Notebook with Dedicated Graphics Card (If you use notebook with Intel Graphics, the Vectorworks Viewer will not work properly. Maybe you will have problem with graphics and crashes). As Nicolas commented, Vectorworks Viewer share the same hardware specification as the Vectorworks Full. Follow the Vectorworks 2019 System Requirements:https://www.vectorworks.net/sysreq?version=2019 If you want to buy a Microsoft Surface, I recommend the Surface Book 2, with NVIDIA® GeForce® GTX 1060 GPU 6GB GDDR5.https://www.microsoft.com/en-us/surface/devices/surface-book-2/tech-specs Regards Paulo Renan Ferrari Quote Link to comment
