Data Tag to reference a symbol within a symbol or group
MTRobin
Hi Everyone,
Attached is a VWX file. I have some lights on a truss and would like to have the data tag label the fixture I select. The data tag references the symbol name. As you can see the data tag is actually referencing the overall symbol and I wanted to see if it was possible to have it reference the lighting symbol within the overall symbol. I tried having it reference the model name within the light info record, but that didn't work either.
Thank you
Maxwell
Data Tag.vwx
At the moment, the data tag will not see through one symbol onto another. If you are trying to insert instruments on a lighting pipe or truss as a symbol, then I would suggest that you make them insert as a group (blue symbol). That's been my approach with 6-bars and the like for some time now and it works well.
Got it. The reason they are symbols within symbols is because I will typically have multiple instances of the same truss overhead or trusses SR that are mirrored SL and I need them to be the same. I think I may just add a small label to the bottom of the fixture in the symbol instead of labeling it after in the annotations.
  • 11 months later...
  • 1 month later...
A workaround i found is the use of Design Layer Viewports for an assembley of symbols. This way you do not need nested symbols
1 create the needed symbols
2 create a separate design layer 'assembley truss 01'
3 create the assembly of the symbols on the design layer
4 make a design layer viewport of your assembly and use this on your main design layer
Now you can still tag all of your symbols that are used through the design layer.
I do not know if this gives you a performance hit. Maybe DLBP's are slower then a symbol with nested symbols?
