Nick_Reid Posted March 7, 2005 Share Posted March 7, 2005 Ok, so I installed the 11.5 update took a look at the productivity improvements and then started the real work on my existing projects only to find screen redraws slowed to 20% of VW11.0.1. What have you done NNA? This is for a range of projects from office interiors with with fully mapped 3d symbols to multi-unit residential developments. In all cases the VW files are more than 25MB. It feels like I'm trying to work on a 5 year old machine. I can only get reasonable performance if I run it on a P4-3200 with 1.5Gb ram. My normal Athlon XP 2000 - 1Gb is almost unusable and as for my trusty AMD 1700 laptop, forget it. I've had to uninstall the update. For me speed is really becoming an issue with vectorworks and larger data sets. Against either AutoCad or Archicad it runs at a snail's pace. Please Please seriously consider addressing this in the next version update. I love the 2d/3d hybrid environment and you have a fantastic feature set but when I use it's advantages on moderately sized projects it feels like minicad is holding me back. Quote Link to comment
Jershaun Posted March 7, 2005 Share Posted March 7, 2005 I second this. Redraw speed is a major problem. Compared to other programs (including cheaper ones) redraws are extremely slow. This issue has to be tackled in the next release. Personally I don't know how other programs' redraws are quicker, I just know VectorWork's redraws are slower. I don't want to know WHY, I just want it fast. Shaun Quote Link to comment
Viper x Posted March 7, 2005 Share Posted March 7, 2005 Check your task manager as it slows down it may be memory leakage like I have, as the memory gets tied up, sometimes close to 2gig vw slooooooooows....... right down. Quote Link to comment
allegro_joel Posted March 7, 2005 Share Posted March 7, 2005 I am using WinXP and I have reverted back to the recommended QT version. The Redraw is really, really slow now. I'm also having problems with the OpenGL that worked fine in 11.0.1. What happened?!?!?!?!?!?!? Quote Link to comment
ionw Posted March 7, 2005 Share Posted March 7, 2005 I noticed that displaying hatches caused drawings to act like this. removing the hatch fill sped it back to expected speeds or better. Quote Link to comment
Guest Posted March 7, 2005 Share Posted March 7, 2005 Allegro, What type of problems are you having with openGL? Do you have Sevice Pack 1 or 2 installed? Have you recently updated your video driver? Quote Link to comment
allegro_joel Posted March 7, 2005 Share Posted March 7, 2005 Sorry for being so vague about the openGL, I am just frustrated. When trying to render in openGL, the program freezes halfway thru the geometry calculation. It also won?t let me do a full final renderworks. I have tried several things including copying and pasting into a new document. I have Service Pack 1 installed. I?ve updated my video driver within the last month. Quote Link to comment
allegro_joel Posted March 7, 2005 Share Posted March 7, 2005 Update to previous post? I just discovered that the new feature, openGL and rendering within a group, works but when I am out of the group I can?t do openGL. Quote Link to comment
Nick_Reid Posted March 7, 2005 Author Share Posted March 7, 2005 Katie P4 3200 has XP Pro SP2 with ATI X800 card. Athlon 2000 Has XP Pro SP1 with Nvidia FX 5200 256Mb Laptop is XP Pro SP1 with Radeon Mobility built-in. I'm using quicktime 6.5.2 on all 3 machines. The copy I have on my install disk is 6.5 and Apple no longer have 6.5.1 on their site so I'm stuck with it. Turning off hardware acceleration and cache makes it run even slower. I had both on when I posted the note. In all cases Vectorworks is substantially slower with 11.5. I've lost patience with it and reverted to 11.0.1 on all my machines and also those of other users in my office. All the other office machines are P4 2800 with SP2 and ATI X300 Cards. As far as I can tell they also have Quicktime 6.5.2 installed. We can't revert to 6.5.1 for the reason above. Quote Link to comment
allegro_joel Posted March 7, 2005 Share Posted March 7, 2005 Nick, I have the full install of 6.5.1, but it hasn't helped. If you would like it, I can email it to you. Quote Link to comment
Guest Posted March 8, 2005 Share Posted March 8, 2005 Allegro, I was just going to ask for that. Can you email it to the address below along with the above description? I will look at it tomorrow when I'm back in the office. I'm sorry you are frustrated. Hopefully we'll be able to uncover the problem to get you back up to speed as quickly as possible. [ 03-07-2005, 09:31 PM: Message edited by: Katie ] Quote Link to comment
Guest Posted March 8, 2005 Share Posted March 8, 2005 Nick, Can you also send a file demonstrating this problem? I would like to run some tests on the file(s) to see what might be causing the problem. Please include a description of the problem along with the above computer specs. I appreicate your cooperation as we look into this problem further. Quote Link to comment
Guest Posted March 8, 2005 Share Posted March 8, 2005 Nick, Shaun - What OS are you using? All of you - Go to File.Preferences> VW preferences. Under the Display tab, do you have the bottom two items checked? What version of QuickTime are you using? Quote Link to comment
Jershaun Posted March 8, 2005 Share Posted March 8, 2005 Windows XP, 512 MB Ram, P4-3.0 gHz, nVidia fx5700 256MB Ram. Tried both settings in display tab and all new drivers. Problem still is there. My argument is that VW has always had a BAD redraw speed from the time I started using the program (Version 7). In AC, for example, if one Zooms extents, the whole drawing is shown immediately. In VctorWorks, if one presses "fit to ojects", some objects are shown, then after a while more ojects are shown and so on until the whole drawing is shown. -Time consuming. Hope this discription is more clear. Shaun Quote Link to comment
Guest Posted March 8, 2005 Share Posted March 8, 2005 Shaun, Are you using SP 1 or SP 2? Can you send a file demonstrating this behavior, please? Quote Link to comment
Jershaun Posted March 9, 2005 Share Posted March 9, 2005 Hi Katie Its service pack 1. It happens to all files however the larger the project, the more severe the problem. I can email you one if you can send me your email address. Thanks, Shaun Quote Link to comment
Philip Van der Vossen Posted March 9, 2005 Share Posted March 9, 2005 Buy a Mac, VW works much better on a Dual G5 then it ever will on a Windows box. =) Seriously, we run both platforms here, and all of our CAD people prefer to work with VW on a Mac, they say it is much faster, and they even said that when our Apple hardware was 2 years older then our Windows machines. Quote Link to comment
allegro_joel Posted March 9, 2005 Share Posted March 9, 2005 I guess I will dump my $3000 machine with my PC software and convince my company to buy another $3000 Mac with new software... that will solve all my problems. Thanks!! Quote Link to comment
Guest Posted March 9, 2005 Share Posted March 9, 2005 My email address is at the bottom of my posts. Quote Link to comment
islandmon Posted March 10, 2005 Share Posted March 10, 2005 As a User of both platforms , I note that very often there are hidden artifacts which Autocad seems to ignore but which VW recognizes with alacrity. A single little test Bitmap render left lying around can cause redraw issues... same for 'invisibles'. Some CAD programs emphasis screen redraw at the expense of accuracy. One reason I enjoy VW is ... accuracy at virtually unlimited scales. Always do a Select All and look for artifacts ... you may be surprised at what you find. Or even better PURGE ! Quote Link to comment
ErichR Posted March 10, 2005 Share Posted March 10, 2005 Noticed a significant slowdown (overnight!). There was nothing changed. Upon opening the file this AM, it started taking 1-2 seconds to recognize and then a couple of seconds to duplicate a line or a block of text. This while zoomed in. Dual-processor XP machine v11.5. The drawing is purged. It's about 5.5 MB. Did the Select All for each of the different layer scales. Quote Link to comment
