michaelk
Slabs loose reshape ability
Anybody else seeing this?
Sometimes slab objects "remember" an earlier shape.  When trying to Edit/Reshape them they show handles for an earlier shape.  I haven't found a good way to fix it.  If I Convert To Group it converts to the correct polygons and floor objects.
The only fix I see is to delete and redraw.
1815516648_ScreenShot2019-02-13at1_14_57PM.thumb.png.ac758b708a4928c44bb2174edec24215.png
Slab bug.vwx
6 answers to this question
Hi Mike,
It looks like you used Add Surface to add the part of the slab that won't go away. Edit the slab's modifier group and delete the poly within.
Matt
Interesting, never thought to look in modifiers.
You are correct, I had used an add surface.
In this case the slab was showing the correct shape.  I wanted to reshape it a little.
I just tried it and by copying the geometry in Modifer and adding it to the geometry in Boundary, it works again.  I can now reshape it.
Is that the secret?  Surface additions live in the Modifier space and moving them to the Boundary space makes them fully integrate into the slab?
Yes. The boundary is the shape of the slab. Adding and subtracting surfaces create modifiers have the option to affect specific components of the slab, so they do not change the boundary.
Thanks, Matt.
I feel a script coming on…
Is the thinking that the slab should be bound by walls, so adding (or clipping?) a surface to a slab is just taking care of an unusual condition?  The example I posted was for a deck which will never be bound by walls but will need to be reshaped several times as the project develops.
LOL!
I believe this is the reason. If a slab is bound to walls, each segment contains bounding information. If you suddenly add more segments, you might get unexpected results. I have not confirmed this is the reason for sure, but I believe it is.
