Kare Posted February 13, 2019 Share Posted February 13, 2019 Hi, I use a report to summarize all my drawings. But i want to be able to sort out some of the drawings according to data in the Sheet title. Sheet Title: 202 Tabel 202 Desk 203 Table 203 lamp ... I use the data ='Title Block Sheet Data'.'Sheet Title' Can i ad something to this string so i can show only the Sheet tile with the number 203 in them? Thanks! //Kåre Quote Link to comment
Pat Stanford Posted March 10, 2019 Share Posted March 10, 2019 Based on some testing I just did, it appears that text field comparisons allow the use of wildcards. Edit your Report and add an additional criteria (under Advanced Criteria is you are not already using that.) Add an additional criteria of: Field Value Sheet Title = 203* The * is the wildcard telling the comparison to accept anything after 203. Ask again if this is nor enough. Quote Link to comment
