Suni
Internal DMX controll (iOS)
Hi
I'm starting to come to terms with there not being any way to controll the lights from an internal lighting software in Vision.
I have done some work now with a MA2 Light sending art-net to my Macbook Pro, but is there any way to use some other iOS compatible lighting software, to somehow send art-net internally directly to Vision? I am going to need to work on visualisations a lot more often then I have access to lighting console. There has to be some solution to this problem.
Check out Nomad by ETC.
I've got an Iron in one of the spaces I work in all the time, so I've used ETC Nomad on my MacBook Pro to push Vision. Give it a shot.
g.
_____________________
gregg hillmar
Author, LIGHT PLOT DECONSTRUCTED
scenic & lighting design
http://www.hillmardesign.com
You can’t buy happiness, but you can buy a bicycle and that’s pretty close.
Thanks for the tip guys. I'm not a regular art-net user, as the first time I needed it was for hooking up Vision.
But that means I can send art-net internally/virtually from Nomad to Vision on the same computer?
Hi Suni
Another tip is to use a second monitor if you can, so Vision is on one and your on pc console software is on the other, makes it much easier.
Regarding Artnet or any of the other protocols the make sure that both vision and the console software are set to use the same protocol, it should then connect automatically.
hope this helps
Jesse
@jcogdell
Ekstra monitor is always a plus. I have been running Vision with Artnet from a MA2 Light console, and that worked without any problems... but my question was regarding the times when we don't have acces to an external console, but still need to work on some visualisations.
And as to the protocols, I was just wondering how Artnet works when the onPC software is on the same computer as Vision. If Vision automatically looks for other internal software sending DMX (Artnet), or if there is any need for extra setings regarding ports and such.
 When you run your on pc console and Vision on the same computer they should connect automatically, as long as both are configured for the same control protocol (Artnet, SACN, MA NET), also MA Net 2 will work without a security dongle in this scenario as well ( dongle is only required for physical consoles, as far as I remember).
Regarding the 2nd monitor if you are using one computer for both Vision and your on PC, it makes life a lot easier.
