Cut out logos
Best way is to import the logo as an image and trace around .......you can then extrude give it textures and for the cnc export as dwg/ dxf.....any problem let me have the logo and I’ll sort it out for you ......ps exhibition designer 46 years.
Edited by Phil hunt
Sorry unless some part of the logo is in a font that you have then you could type the letters and convert text to polyline....ungroup and then extrude and resize the letters to the desired size......of course you may have to trace around the logo itself.....if you have the logo as an illustrator file in outlines you could export the logo as a dwg/dxf and then import into vectorworks.     Hope this helps.   Phil
  • 4 weeks later...
  • 2 weeks later...
