Martijn Wingelaar Posted February 7, 2019 Share Posted February 7, 2019 Hello all. BenV posted a cool node last year. He made a swivel CB. Now I took his idea to use it with a truss bookcorner I've had a job last week where I needed it with braceworks. The only problem is that the symbol is on in an angle but with the node I can adjust it I only don't get it working with a braceworks truss symbol. Does anyone knows if that's possible and how? Greetings Martijn Bookcorner example.vwx Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted February 7, 2019 Vectorworks, Inc Employee Share Posted February 7, 2019 In order to make a symbol work with Braceworks the Truss Record must be applied. This is what the Auto Connect engine uses in order to generate the red line that shows when a connection is possible. I am not sure if you can apply the Truss Record to this particular Marionette object because of the wrapper and how it changes the way the object behaves. @Marissa Farrell may know more on whether it is possible or not. When I use hinges I create a symbol with a specified angle and setup the Braceworks data as a L-Corner and this works well and allows the Auto Connect to generate. Quote Link to comment
Martijn Wingelaar Posted February 7, 2019 Author Share Posted February 7, 2019 Hello Justin. I use the hinge that way but I liked the wrapper couse it made the angle adjustment easy. I hope there is a solution with a Braceworks symbol. Quote Link to comment
