line-weight 856 Posted February 6, 2019 (This is VW2018) The screenshot is from the attached file. The model contains two objects: a wall object and a polygon object ('green gridline'). Section one cuts through the wall and the green gridline, and both show up as expected. Section 2 cuts only through the green gridline. The wall shows in the background in elevation as expected but the green gridline does not appear at all. Why is this? (File contains 2 saved views so you can look at the model and the sheet layer) gridsect.vwx Quote Share this post Link to post
line-weight 856 Posted February 7, 2019 Further testing suggests this happens when the section line doesn't pass through any non-planar objects. So is this a bug? Quote Share this post Link to post
Kevin McAllister 1,162 Posted February 7, 2019 It looks like this was also solved in VW2019 😕 Kevin 2 Quote Share this post Link to post
