Guest Magi Posted February 4, 2019 Share Posted February 4, 2019 Hi, I tried to reproduce fundamentals 2019 movie organic wall form but it seems to be impossible. Is there anyone who is able to tell me how to create that stepped open space inside the "wall"? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 4, 2019 Vectorworks, Inc Employee Share Posted February 4, 2019 That was created by first creating the overall shape with a Subdivision, then using duplicated extrusions spaced out in an array and subtracting them from the solid to give you multiple separate slices. Quote Link to comment
Guest Magi Posted February 4, 2019 Share Posted February 4, 2019 Does it mean that primary subdivision object was converted to solid for subtracting than again turned to subdivision? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 4, 2019 Vectorworks, Inc Employee Share Posted February 4, 2019 I believe the very last phase was the solid subtract of the array of extrudes. Quote Link to comment
Popular Post Kevin McAllister Posted February 4, 2019 Popular Post Share Posted February 4, 2019 This is a good time to link to this wish again - Kevin 5 Quote Link to comment
Guest Magi Posted February 4, 2019 Share Posted February 4, 2019 I agree. Nevertheless, I continue to explore 2019 subdivision and found that bridge mode is not working for me for 3D shapes. I created two separate tubes, opened their ends, combined them together and tried to bridge the edges. No result. Does anyone know what am I doing wrong? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 4, 2019 Vectorworks, Inc Employee Share Posted February 4, 2019 Bridging will close two open edges, not two edges adjacent to hidden ones I think. If you delete the face instead of hiding it, you should then be able to bridge. If not, please post the object or a portion of it in an example file and I'll take a look. Quote Link to comment
Bas Vellekoop Posted April 19, 2019 Share Posted April 19, 2019 I was wondering the same. Is it possible to bridge the two separate subdivision object in the attached print screen? The file is attached. combine.vwx Quote Link to comment
Bas Vellekoop Posted April 19, 2019 Share Posted April 19, 2019 Okay so I found a way to do it by composing the two subdivision object (1: select objects 2: modify menu 3: compose command) Now I run in to this problem when bridging the gaps: Is there a easy way to solve this? Quote Link to comment
zoomer Posted April 19, 2019 Share Posted April 19, 2019 (edited) I think the Bridge Function came already with VW 2018. I tried it at that time and it worked ok AFAIK. Also there came a Symmetry Option, with a bicycle saddle example, where you model one half only and activate the mirrored half later. Edited April 19, 2019 by zoomer Quote Link to comment
Bas Vellekoop Posted April 19, 2019 Share Posted April 19, 2019 2 hours ago, zoomer said: Also there came a Symmetry Option, with a bicycle saddle example, where you model one half only and activate the mirrored half later. The object I want to model is less 'mirrored' then it seems, so I would like to do it without mirroring. Bridging the object works, only it seems that the bridges flips over to the other corner in this case so you get this strange cross you see in the screen cap above. Quote Link to comment
zoomer Posted April 19, 2019 Share Posted April 19, 2019 That is why I mentioned symmetry option ... (I see it is called "Mirror Modeling Mode" and needed some time to find it and get how it works 😉 ) .... Because I thought you mirrored manually and that would be the reason for your flipped "Bridge" I think I bridged 2 Faces at that time. Have you tried closing (relatively new too) the holes on both sides and bridge these ? Will it also be flipped ? Quote Link to comment
ashot Posted February 16, 2020 Share Posted February 16, 2020 time frame between 15 to 25. Please anyone can explain in steps, how it is done. Quote Link to comment
rjtiedeman Posted December 3, 2020 Share Posted December 3, 2020 (edited) I agree completely. You have to go back to the basic subdivision tutorial. However then they blow through the basics in the first 2 seconds and I am not sure how you would do the internal framing. There seems to be more Vectorworks tutorials on Youtube than in the VW library . Edited December 3, 2020 by rjtiedeman Quote Link to comment
