sam@pcd Posted February 4, 2019 Share Posted February 4, 2019 Hi, Is there a way in which you can edit the 3D part of a symbol and it will automatically change the 2D part of the symbol? It just becomes a bit tedious when resizing a shelf, table etc... Thanks Quote Link to comment
willofmaine Posted February 4, 2019 Share Posted February 4, 2019 Auto Hybrids. Pretty much anything you model in 3D (3D only, and including 3D symbols) you can make into an Auto Hybrid, so that when you change the 3D geometry, its 2D representation automatically updates. After creating your 3D geometry, in Top Plan view go to AEC > Create Auto Hybrid. If you have multiple instances of your object (that will all be the same) you can make a symbol out of your Auto Hybrid object; the symbol you create will automatically be a 2D/3D Hybrid symbol. Alternatively, for things like shelves and tables, you might be able to use Plug-In Objects; these are inherently Hybrid objects where both the 3D and 2D are automatically updated based on your input parameters. HTH 1 Quote Link to comment
