Developer Wiki and Function Reference Links Read more... ×
KroVex
If in String - Result not as desired
Hi There
I have a Question about the "If in String Node":
The following circuit should me depending on the value, set a prefix, or not.
However, the "If in String" not only outputs False / True, but also the sSub input string. How can I prevent that?
228370415_Bildschirmfoto2019-02-04um11_12_50.thumb.png.9c8d8a81d5508bb94a2b08b15b9bcdfb.png
Wohnung_marionette.vwx
Greeting KroVex
It looks like you aren't getting values returned from your Get Record Field nodes (They are resulting in "<Unknown Value>"), which will affect the rest of your network.
You can see that you have wires coming out of your Filter nodes that have 0 items, which will prevent the network from running correctly.
I would suggest looking into why values aren't being returned appropriately from the Get Record Field nodes and going from there.
I looked into this - there is something wrong with the Get Record Field node - I replaced all of the ones that existed with one from the default content library and the network now works appropriately on my end.
I will note, I am using 2019, and am not sure which version you are using (though I can tell it's prior to 2019) so please let me know if you're still having an issue and I will send you a file with a new node in the correct version for you to replace them with.
As Marissa mentioned
1. Replace code inside "Get Record Field", which is from 2016, use an outdated vs.GetType() command and is not update-ready.
2. I would solve the prefix with the if node:
1436855527_Bildschirmfoto2019-02-05um09_52_25.thumb.png.79610d84dd2a53cd677d9dc6d6bdebb0.png
3. I would try to keep the symbol record format workflow. Because it is so much easier to change the look of your stamp.
4. Uploaded an update of my example here:
Edited by DomC
