VvierA 8 Posted January 31, 2019 Hi everybody, I was looking around a little bit about information on how define the linestyle of an object. There is a Linestyle bug thread but it doesn't help. If I try to run the network Marissa provided in the last post I get an error message. My task seems to be easy: I'd like to define the line style for a polygon. But how do know the index numbers for the self defined line styles in my document? Thanks VVierA Quote Share this post Link to post
Marissa Farrell 464 Posted January 31, 2019 Are you in a non-English version of Vectorworks? I've learned that my network may only work with English. I have a node in progress that will work in any language. Quote Share this post Link to post
VvierA 8 Posted February 1, 2019 Yes, it's the German version. Do you know of some kind of workaround, until the network works with non-English versions? Quote Share this post Link to post
Marissa Farrell 464 Posted February 1, 2019 The issue is that the file name for line styles is translated in non-English versions. You should be able to change the filename in the node script to what your file is named and it should work. Quote Share this post Link to post
