Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
PVA - Jim
Concurrent Open Documents?
27 members have voted
  1. 1. How many documents do you normally keep open on a regular basis in Vectorworks?
    • 1
      1
    • 2-3
      17
    • 3-5
      7
    • 5-8
      0
    • 8+ (The limit of 8 documents interferes with my workflow)
      2
How many documents do you keep open on a regular basis in Vectorworks? Do you keep this lower than you would like because of limitations in Vectorworks? What kind of work are you doing when you have multiple files open at a time?
Share this post
Link to post
I frequently have about three to five documents open consisting of the following:
  • One main file.
  • One or two files of stuff that I am referencing.
  • Sometimes another file for another project I am working on (when I get a phone call).
  • One or two files where I am working on tasks discretely from my main file.  I do studies, or copy things out of the main file more easily work on them.
I frequently come up against the maximum file open dialogue box, and then I realize I have to close things up.
Share this post
Link to post
I keep individual "units" in separate drawing files and then reference these into a master drawing file.
So at any time I will have 1 to 3 pipe and instrument drawings (separate files) along with the master layout, and multiple (at least 3, on the last project I would have liked to have had 6) unit layout files open. that way I can easily switch files, make the edit and then update the reference to fix the master layout.
When reading the forum and trying to help other users I often open a new file (or 3) and tend to look back through my historical files to see what might be applicable. Often I hit the file limit.
Neither are likely typical use cases for anyone other than me.
Share this post
Link to post
Because I keep everything for a project in a single file whenever possible, I often only have one file open. I open and close other files when I need to access other projects or resources but I tend to close them again when I'm done, knowing that it can affect VW performance depending upon the file sizes. My project files can be quite large because of the one project / one file workflow.
Kevin
Share this post
Link to post
I also tend to have just one file open at a time. This is mainly because I am usually working on one main project at a time. Unfortunately also with VW crashing at random times it means less hassle retrieving drawings.
Share this post
Link to post
I avoid more than 3. most files are no more than 60000kb The issue with the multiple tabs open is still occuring?
Share this post
Link to post
At our office (VW Architect) we do often work either with 2-3 files (e.g. building model + schemes/diagrams + utilities such us references etc.) or with  3-5 files when working with referenced files on final design stages (e.g. landscape general model + building models + details).
Something I would really appreciate/need would be the possibility to work/browse  (zoom/pan/etc) with 2 different drawings/files while a command/window is open/active on one of them. For example:
  • File 1: 3d building model > editing wall styles/components
  • File 2: 2d details drawing > checking/verifying some information (thickness, materials etc) needed for wall components
It may sound silly but right now we do often use screenshots to copy data or old style writing notes (and copying data) on paper.
Edited by STR
Share this post
Link to post
It's not so much how many I open when working, but how many I need to open to print the fabrications drawings (could be 50).
It's not reasonable to print as I go since they get lost in the communal printing pile. I like to print them in alpha-numeric order in one pile so the job doesn't separated and get lost.
If VW doesn't allow more than 8, maybe a printing macro is what is needed.
Share this post
Link to post
I usually have the main project file open,  then open other project files to grab details as needed.
One issue i have found with having multiple files open at the same time is that sometimes the navigation browser gets stuck on one of the files and won't switch to the other files.
Share this post
Link to post
