Developer Wiki and Function Reference Links Read more... ×
WhoCanDo
Creating a wall with dotted center line
Hi,
I want to create a wall type with a dotted line cavity. image.thumb.png.8fdb9c9d577b8f0a7258f727b0a9d532.png
In VW2018 this worked ..
procedure test;
var Response : boolean;
begin
Response := DeleteAllComponents (nil);
Response := InsertNewComponentN (nil, 1,  5, 0, 10,  6,  0, 2);
Response := InsertNewComponentN (nil, 2, 20, 0,  6, 10, -2, 0);
SetTool (13);
end;
Run (test);
However in VW2019, it doesn't.
It seems that the -2 is the cause of the problem. -2 is the line type "Dash Style-2" from the standard pallet.
If -2 is changed to 2 in this script, the wall looks like above with a solid cavity line.
Can anyone suggest what changed between VW2018 & VW2019?
Please note: that I was using InsertNewComponent in VW2018 but now I am forced to use InsertNewComponentN
Try using Name2Index('Dash Style-2') in place of -2, as the number will vary depending on the order the dash styles were imported into the drawing. Obviously the dash style will already need to exist in the file for this to work.
Thanks Julian, but that didn't work either ☹️
procedure test;
begin
Response := InsertNewComponentN (nil, 2, 20, 0,  6, 10, Name2Index('Dash Style-2'), 0);
SetTool (13);
end;
Run (test);
Sorry you will need to put a minus in front of Name2Index, but also note that you may not see the line is dashed because the line from the adjoining component is solid, so you might need to do something like this:
procedure test;
begin
Response := InsertNewComponentN (nil, 1,  5, 0, 10,  0, 0, 2);
Response := InsertNewComponentN (nil, 2, 20, 0,  6, 10, -Name2Index('Dash Style-2'), 0);
SetTool (13);
end;
Run (test);
