mreadshaw Posted January 30, 2019 Share Posted January 30, 2019 When I use the mirror tool with instruments the the tool activates the Z rotation option. This only seems to happen if you use the mirror while in a 3D view. It sets the rotation to 7.01671e-15 which results in a 180deg rotation of the instrument. It doesn't affect the rotation at the top of the OIP just the Z-rotation in 3D Orientation. It Is there any fix for this or is it just a bug? Thanks Quote Link to comment
markdd Posted January 30, 2019 Share Posted January 30, 2019 You’re not wrong! Mine behaves in a similar way although the angle of rotation is 90 or 180. Definitely a bug. Although I think the tool was designed to only wok in 2d, I think now that the rotate tool works in 3D with instruments, it makes sense that the mirror tool would do the same. Quote Link to comment
